New case for m-ITX, something slim ?
10 Jul 2006
Tredegar Wales
Hi,
I currently have the IN-WIN 301 with the spec as in the attachment. Are there any thinner cases out there that I can use ? Happy to use one with a built in power supply as long as my graphics card will fit. Also would like a glass side(s) but not a must.
Thanks.
Your system is Micro ATX, not Mini ITX. The only really thin Micro ATX cases are either bespoke Dell Optiplex junk or the Bitfenix Pandora which you can't get any more (and I wouldn't wish either of the two I have on my worst enemy).
In Win 301 is already pretty small, isn't it?
Yes sorry I meant Micro ITX. Yes the 301 is pretty narrow, I wasn't sure if there was anything smaller available but I have a good look round and can't find much either.
Theres not many thinner cases as it has to allow for the width of the GPU
The dimensions of that case is H x W x D) 365mm x 188mm x 370m
This does but nee to check limitations.
Meshroom S V2 is 167mm wide.
NCase M2 is 166mm.
SFFTime P-ATX V3 - 81mm & N-ATXV2 - 101mm.
4 cases above can do M-ATX boards and smaller than the Inwin.
Apart from the Ncase the other 3 will need low profile cpu coolers so worth mentioning your current components.
