new case from old stacker
24 Jul 2006
Hi
heres the dilema, im looking for the best way to reduce heat for my computer becasue its getting pretty hot this summer, my current case is an old stacker, black/silver trim, can anyone recomend a coller/better case, for <£200
Not going to happen. The Stackers are one of the best potential coolers out there. The old ones I mean.
What is your rig and current cooling, much better off sorting your current; excellent, case out first.
If it isn't crashing then its fine. If it is then you need to change it/lower clocks.
My winter clocked X2 @ 2.5ghz is still at 2.5ghz, hitting 55C load on the hottest day of the year. I have a stacker.
CR.
Maybe your fans need replacing? I'd recommend Panaflo's.
A thorough clean-out might help reduce temps also.
Have you considered watercooling?
The original Stacker is one one the easiest to fit a triple radiator into, and would be easy to get very efficient cooling at very low noise levels.
well money is limited to around 400 quid as my 18th is coming up, the fans inside are acryan 120mm uv, 80mm uv - top, the hardware is;
Opteron 144 @ 2.4ghz - for summer, with a vapochill micro
asus a8nsli deluxe
120 seagate hdd- replacing with 1 or 2 hitachi t7k250's 250 model - so more heat there
7800gt @ 450 / 1100
xfi platinum
tagan 580 watt modular
2gig gksill ram oc'd to something that i forgot lol
i have the case in wtx form atm because it was recomended elsewhere and did keep it nice in winter but is that a bad idea for summer, the wires all all tidied and sorted and there not much dust in there.
would an aluminium interior provide better cooling maybe?
sorry for the second post but would you guys recoment any harware upgrades in taht £400 budget, bearing in mind that quad core is coming and g80 also - i dont mind waiting
Keep the case, get a scythe ninja or tuniq tower 120 cooler (if you can find one) and a zalman vf900 for the graphics. Watch your temps plummet ;)
Post some pics of the interior of the case too, setting up the current fans correctly and tidying wires can help. As can cleaning out dust etc.
cant psot any pics because i dont have a camera yet, ill try borrow one soon,
thanks for the info, what about the arctic cooling vga things, dont they exhaust air from the case and if so wouldnt that be better?
also ar the panaflo fans quiet?
Might make 1c diference to your entire system but won't cool the graphics as well.
can anyone suggest the best way of gonig about mounting radiators or what type to buy as im not familiar with watercooling, also can anyone with a stacker and w/c state cpu type and temps please
Swiftech H20-220 Apex Ultra Watercooling Kit Price: £137.95 (£162.09 Including VAT at 17.5%)
