New case, H440 with three loops?
13 Oct 2011
Bristol
I currently have an old Lian Li PC-P80, on wheels, with a massive hole in the base from the 360mm rad I had in my old build. Some of the hard drives have nowhere to fix in place as I'd cut lots of the case apart for the old build.
I need something new. I want to put both GPUs (reference 980s) on water. I quite like the look of the h440.
I currently have a H80i on the CPU, I'm happy to keep this, I'm thinking this gets mounted in the rear fan location above the PCIe slots.
I want to put both GPUs on 240mm rads : https://www.overclockers.co.uk/search_results.php?keywords=kraken+tech+labs&_=1427374895618
But I don't know where I'd put them both.
One can go in the roof, but what about the other?
There won't be much space in the PSU bay as my AX1500i is big. I have two SSDs for the 2.5 sleds, but I then have 3x4TB drives for Steam, media, etc which need to fit in the front (or somewhere else if I have to remove the front bays.
Do I stand a chance or should I look at another case?
I have just done some very quick measurements and with a 240 in the front I believe you would only have two drive bays left but there would "possibly" be enough room at the top to somehow mount a 3rd hard drive up there.
I have never tried to fit a 240 in the front to be honest so hopefully someone will come along with more experience!
the phanteks pro would also be another option for you.
