New Case (Help)
4 Aug 2009
Bournemouth, UK
Hi Guys
I'm looking for a new case for my I7 920 Rig, its currently in a HAF932, but the case is abit old and battered now.
The case would need to be a full tower case, with good air flow......
Please giveme some idea's
Thanks
Hay
but the case is abit old and battered not
Case which was announced just 1½ year ago...
Just what are you doing with it? Using it as anvil or work bench?
(but agree about styling being as long lasting as chewing gum)
Anything else than E-ATX case would be lot less spacious so start by skipping non E-ATX cases.
What do you guys think of the Silverstone TJ-07??
Excellent for heavy water cooling with minimal changes, nothing to talk about for air cooling.
While chambered design works great in Antec P18x that doesn't mean other makers have any idea what they're doing. (and Antec got design from SilentPCreview's founder)
Also compared to open space of single chamber you surely wouldn't like space eating effect chamber divides have.
Out of suggested cases only Cosmos is E-ATX case and while very silencing friendly cooling wise it's seriously intake limited with complex internal design/messy airflow.
Coolermaster ATCS 840 has very similar layout.
Then there's quite configurable (main HDD cage can be removed, top panel is separate) Lian Li A70F with huge amount of drive bays and silencing friendly A71F version with direct noise escape path blocking door.
