NEW CASE HELP
22 Mar 2014
Plymouth
Hi there I looking to buy new case that will fit my computer but I'm having difficulties to find one.
My needs are that case should be relatively quiet and cool. Budget is up to 150 pounds. I would be thankful for you help.
My specs are:
I7 4770k
MSI z87-gd65
Corsair h100i
Corsair AX760
EVGA GTX 780 SC ACX
Bitfenix Ronin:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-129-BX&groupid=2362&catid=1850
This is a belter of a case. I fit a H105 into it by putting the fans on the top of the case (but still covered by the roof shroud) and the radiator inside the case in the roof, but I could easily have put everything inside the case since my motherboard had no heatsinks on the top edge.
Will fit the H100i no problem.
May need to get another fan for the case to assist airflow - comes with 1 120m in the front, 1 120m in the rear. I moved the rear for dual 120mm in the front and got another 120 for exhaust.
Thank you for all yours replies. Do you guys know when Fractal design R 5 windowed will be available? Also is there a huge difference in noise between sound damped case and case with quality fans as I have 6 sp120 fans and aquaero 6 pro fan controller to control them?
Unfortunately we have no current plans to stock Fractal, mainly due to the amount of stock that was damaged in transit due to poor packaging and the difficulty of sorting these products under Fractals warranty. Regarding the difference in noise, good quality fans gets you so far, but if you're aiming for silence, a noise dampened case is hard to beat.
Okay thank you for your reply ChugNorris. Also are you able to provide detail on why you do not retail fractal design as when I click in the link it come with this message:
SamyBoy13, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Basically to sum it up, their packaging and warranty support were poor, so were dropped as it was costing too much.
Sorry about that, I've amended my post now to give you the low down.
