New case ideas
20 Oct 2011
Work... Usually
Evening All,
Currently I have a huge heavy water-cooled Enthoo Primo. It's a great case but it's also massive and weighs a ton. I'm moving house and need something with a smaller form factor.
It needs to fit the following:
Rampage V Extreme
5930k
Sli 980's until I get a single 1080ti
Superflower 1200 watt platinum
3 ssd minimum
All of this will be going on air and away from custom loop.
So I'm looking for something smaller and lighter that will fit all that in. Not too concerned about budget. Have looked at the Evolv Atx and also the Corsair 740.
Any other suggestions?
Decided to get the Corsair Air 740 along with a load of RGB goodness. I'll post a pic once I get it built up.
Very smart case, i like the door theyve added i bet that makes things easier when fiddling with your build... It will look great with lots of RGB bits... Look forward to seeing the pics when you upload
