well, heres my problem its going to cost too much to put my armor right in terms of cooling and spending like £150 just to sort out air flow is a shocking amount and I might as well buy water cooling for that.
so new case time....and CPU cooler (however I got that covered) I can sell my old stuff so I m not too fused.
my candidates
the chieftec
CX-05B http://www.overclockers.co.uk/showproduct.php?prodid=CA-042-CT&groupid=701&catid=7&subcat=1408
Antec 902
http://www.overclockers.co.uk/showproduct.php?prodid=CA-110-AN&groupid=701&catid=7&subcat=160
also I will look at the antec 300 if it suits, think I may land up putting a side window on
Silverstone
http://www.overclockers.co.uk/showproduct.php?prodid=CA-055-SV&groupid=701&catid=7&subcat=1092
coolermaster
http://www.overclockers.co.uk/showproduct.php?prodid=CA-157-CM&groupid=701&catid=7&subcat=29 or
http://www.overclockers.co.uk/showproduct.php?prodid=CA-175-CM&groupid=701&catid=7&subcat=29
now do you see my problem ?
I can't choose specs are in my sig so the case needs to be big for two dual slot cards but not too big and have quite a lot of air flow, also i have quite a lot of optical drives 2 and a card reader that takes a 5 and a half inch slot up.
my candidates
the chieftec
Antec 902
Silverstone
coolermaster
would like to see inside through but nothing which a metal saw and a a bit of sanding can't fix to sort that out and perspex.
