new case need f-panel help plz
14 Jul 2011
just got new case and i need help with the f-panel .
i have gigabyte ga-8i915pm mb and i have 5 wires form case for f- panel.
hdd led
power sw
reset sw
power led +
power led -
just need to know witch way round they go
plz help me :)
yes going from right to left on the top row, notice it says pw+ so check the connectors you have and that should put them the right way round.
daft question but arn't the details on the mobo itself, next to where they plug in, know they used to be.
Best way to check if it's the case switch is to manually turn the motherboard on and check that the power is flowing through the system. Get a screwdriver (or something metallic with an insulating bit where your hand goes!) and short out the two power pins - that should turn on the computer. Does your motherboard have an LED that switches on when there is power to it? Mine has one to indicate that there is power to the mobo (when it's not on) and then another when it has been turned on.
ok ty been on to the place i got it form anjd i got to ring them tomorrow but i have put it all back in old case and works fine something to do with f-panel
So it works when you short the two power switch pins on the motherboard with a screwdriver, but not when you connect the switch and push it?
