Hi'a
I bought a cheap case from a diff website to build my misses a pc,
So get it delivered, open it up and...
rather then having 9 machined holes for the copper standoffs which the m/b sits on it has just 3. All along the front near where the h'ds sit.
The other 6 holes are pushed out like nipples and it appears that the m/b is to sit on them?? I'm a bit concerned that if i was to do this it would screw the m/b by touching direct to the case
E:\New folder\New folder\2009-10-16\084.JPG
i've tried to attach a pic don't know if it'll work tho.
any one experianced this kind of design before?
