Afternoon.
Yesterday after i bought an Akasa Eclipse 62 case upgrading from a thermaltake. I switched everything over into the new case after hours of rebuilding i was done and very happy with the new case and how tidy it looked.
My first boot was fine everything at stock. When i went to overclock to get back up to 3.35 Ghz it just shuts itself off and boots back up, I've tried lowering the clock but it just won't stay on. After the overclock it'll boot into windows then shut itself off after that i'll get as far as 'Start windows normally' before it'll shut off and restart again.
This is incredibly baffling as i can't really seem to figure whats the problem, I've tried upping a few volts for abit more power but the same problem consists.
The settings i was using were fine before here they are:
FSB Fre 371
NB FSB Strap 333 Mhz
CPU Volts 1.4500
FSB Term Volt 1.40
Memory Volt 1.9
NB Volt 1.40
They never failed me before after running prime95 for 5 hours and a lot of hours of hard gaming but now it just refuses to stay on.
Does anyone have any possible suggestions as to what the problem could be? Temperatures aren't high (had enough time to load CoreTemp)
System specs are in sig.
Thanks.
FSB Fre 371
CPU Volts 1.4500
FSB Term Volt 1.40
Memory Volt 1.9
NB Volt 1.40
Thanks.
