New Case Range at OcUK - Lancool
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
OcUK have introduced a new range on cases. LanCool.
Lancool K1 Midi Tower Case - Black (No PSU)
The K1 features include an all aluminum chassis exterior, giving the case the traditional hair-line brushed finish with black anodizing, while the internals have finely honed edges to keep up high safety standards. The case is designed for the power user, so they are wide and rigid, using the minimalist style where every aspect is well thought out and has a specific purpose. There are no frills, but lots of thrills, especially if you are a modder. The outer shell; all in aluminum, is easily cut and modified, while the internal core; made of steel is 40% stronger than an all-aluminum case. The added rigidity makes these cases ideal for carting around to LAN’s to show off your kit.
- Aluminium Front Bezel
- Motherboard compatibility: ATX and MicroATX
- Drive Bays: 5 x 5.25" Bays & 5 x 3.5" Bays
- Front Cooling: 1 x 140mm Silent Fans
- Rear Cooling: 1 x 120mm Silent Fan
- I/O Ports: 2 x USB2.0, 1 x FireWire and 2x Audio
- Dimensions: 210 x 450 x 490mm (WxHxD)
BUY NOW for only £75.99 inc VAT.
Lancool K6 Midi Tower Case - Black (No PSU)
LanCool use the high quality Taiwanise made aluminum alloy panels on K6. With hair-line brushed, anodized treatment gives a great looking finish. The sharp edges have been removed or covered up with protection for maximum safety during installation. The K6 has some exciting features to help reduce noise, giving you a quiet system allowing you to hear every footstep and gun shot in games. The HDD caddy has an anti-vibration suspension mounting system, there is a unique noise dimmer panel fitted to the front, behind the intake fan, and anti-vibration springs on the chassis itself all combined making this case very quiet.
BUY NOW for only £78.99 inc VAT.
Lancool K7 Midi Tower - Black (No PSU)
Lancool cases are made with the highest quality materials combined with excellent workmanship. The chassis is made from hardwearing steel with the external aluminium panels. The K7 is equipped with a powerful cooling system for maintaining the most stable computer even when overclocking, with many perfomance cooling solutions there is a cost of noise involved, but the K7 does fight against noise with some very good accoustic dampening features including rubber HDD suspension kits and anti-vibration springs.
- Drive Bays: 3x 5.25" Bays & 6 x 3.5" Bays
- Front Cooling: 2 x 120mm Silent Fans
- Dimensions: 210 x 460 x 489mm (WxHxD)
BUY NOW for only £67.99 inc VAT.
Lancool K7C Midi Tower - Champagne (No PSU)
BUY NOW for only £80.99 inc VAT
I haven't looked into them a lot yet but:
1. Are the differences between the 4 purely cosmetic or is there more to it?
2. Will you be stocking the side window for the range?
