New Case Recommendation
16 Oct 2008
Birmingham
Hey guys can some of you kind people here spec me a case?
After something £50-£70 that preferrably has cable management, fan filters and not millions of disco lights but is just a simple good case to work with :) Was looking at the antec 300 but not sure if it has cable management?
Cheers
CM Dominator/Gladiator? NZXT do a few but they're usually filled with all the 'bells and whistles', so not what you're after.
Looked at the Gladiator and it looks a bit empty compared to the lancool? And the cable management on the Dominator looks poor compared to the lancool.
Empty? It'l have no hardware in at first... as long as there's enough space for yours then i don't see the problem. And there's a lot of people on here with the Dominator, who speak very highly of it. From what i've seen it's got amazing cable management...
Lol I meant as in features not actual parts :p Perhaps some Dominator owners can come here and tell me about the case? :)
You can probably find more reviews of the Lancool PC-K62 around. Its exactly the same case as the K58 but comes with two extra 140mm fans that have leds and the inside is finished black. Apart from that all the cable management and tooless stuff is the same.
Just some help if you need some more info for the K58 :)
The CM-690 is a good case though its been out for a while now. Heard a new revision is going to come out sometime next year.
