new case required small ATX case
9 Dec 2006
@ManCave
im looking for a small ATX case sounds weird,
but basically i'm using a Corsair 600T at the moment. for my spare PC
which now is a Windows server 2012 standard edition
so i want a smaller case to hide away in a cupboard or corner.
pc spec is
i7 940 ~ 2.0ghz (down-clocked)
12GB ram
2x 1TB HDD
430GT
HX850w
i used all spare parts to put this together,
looking for somthing small but with mutiple hdd spaces would be perfect:D
I've got an A05NB... With a 2x5.25 drive cage and a 2x2.5 drive bay that sits where the floppy could go. So fits 6 hdds and 2 sdds. It's tiny. But a proper case. So long as you don't want a big gpu in it... Although the newer ones might be better for it as the motherboard is no longer inverted... I can only fit a 7850 in mine.
cheers,
you don't know the max cpu cooler height do you?
mine is 160mm you see
edit 165mm 5mm extra should fit
