- 5 Sep 2003
- Cardiff Geordie
I've just bought an Antec 300 case from MM - good bargain!
Now I have to decide how to power my system. It's an Intel Core 2 Duo system with a couple of gigs of RAM, 2 x SATA HDDs, on-board graphics and will be powering quite a lot of external stuff, both over USB and firewire. I'm not planning on doing any gaming with it, just recording and mixing music projects.
The Antec 300 has a bottom-mounting for the PSU, and has a grille in the bottom/back for PSU fans, so I'd ideally like to be able to use them with a dual fan PSU. As I'm recording music, noise is a bit of an issue, but it's only bedroom stuff so not a HUGE dealbreaker.
I was thinking somewhere around 400W..... any suggestions?
EDIT: The 'Antec PSU Calculator' reckons I need a 293W supply.... also, what I said about the case having a bottom grille for psu may or may not have been actual ********... don't know where I got that from?! Coulda sworn it had one when I first saw it?!
Now I have to decide how to power my system. It's an Intel Core 2 Duo system with a couple of gigs of RAM, 2 x SATA HDDs, on-board graphics and will be powering quite a lot of external stuff, both over USB and firewire. I'm not planning on doing any gaming with it, just recording and mixing music projects.The Antec 300 has a bottom-mounting for the PSU, and has a grille in the bottom/back for PSU fans, so I'd ideally like to be able to use them with a dual fan PSU. As I'm recording music, noise is a bit of an issue, but it's only bedroom stuff so not a HUGE dealbreaker.
- why bother looking at anything lower?
