New cooler for 3570K.
Hi Nevakonaza, there is no curing time with our thermal paste.
Awesome thanks! ;)
When installing mine I install the mount complete.. including the piece with screw in the middle. Then tightened the 4 mounts in the mother board. Them put the piece with screw in middle on the heatsink.
I
I should have done it like that as well :p,Never mind though its done now.
Ive noticed though,Not sure if the same happens on all 3570Ks,But the temps on the cores suddenly jump up then back down again?
Core 1 & 2 runs about 5-6c hotter than the rest at idle?
according to core temp,My max temp on core 1 while just browsing the net is 44c which seems kind of hot don't you think?
Added that bit not so much for you as for other. ;)
The CPU spikes, does CPU load spike at same time? My guess is it does. ;)
I assume your ambient temp is quite cool?
What speed are your fans running?
My CPU idles at 37-41c because my fans idle down to 650rpm.
