*** New Corsair Parts Added Amazing Deals to be had ***
Suspended
18 Oct 2002
OcUK HQ
*** Corsair XMS3 DHX 4GB DDR3 1333C9DHX Twin3X (2x2GB) (TW3X4G1333C9DHX) £55.99 ***
The TW3X4G1333C9DHX is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using Corsair’s latest high performance heat sink with Dual-Path Heat Xchange (DHX) technology. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1333MHz at the low latencies of 9-9-9-24.
- Each module pair is tested together at 1333MHz
- Tested and packaged in pairs
- Packaged together immediately following system test
- Tested together at 1800MHz, Vdimm = 1.6V, at latency settings of 9-9-9-24
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz
- 4096 Megabytes of DDR3 memory
- Two matched TW3X4G1333C9DHX modules
- Using DHX technology providing maximum cooling
- 100% tested at 1333MHz in high performance DDR3 motherboards
- Lifetime warranty
Buy Now @ £55.99 inc VAT
*** Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C7 (1600MHz) Tri-Channel (TR3X6G1600C7) £94.99 ***
This 6GB triple kit memory solution runs at an incredibly fast 1600MHz at CAS latency of 7-7-7-20, 1T. So not only do you get to run your system at 1600MHz but with these tight Latency timings your system performance will rock.
Key Features
- 6GB memory kit (3 x 2GB) for use with Triple Channel Intel Core i7 memory solutions
- 1600MHz
- Latency of 7-7-7-20, 1T for maximum reliability and performance
- XMS Heat Spreader
- Limited Lifetime Warranty
Buy Now @ £94.99 inc VAT
*** Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel (TR3X6G1600C8G) £79.99 ***
Corsair's value for performance 6GB 1600MHz CAS Latency 8 memory kit solution for the Intel Core i7 processor.
The XMS Series TR3X6G1600C8 G is a 6144MByte kit of DDR3 SDRAM DIMMs built using Corsair’s new high performance heat sink. This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at latencies of 8-8-8-24 at 1.65V VDIMM.
- New XMS3 Heat Spreader
- Matched Triple Kit
- 1600MHz
- 8-8-8-24
- 1.65V
- Lifetime Warranty
Buy Now @ £79.99 inc VAT
*** Corsair Dominator GT 6GB (3x2GB) DDR3 PC3-14400C7 (1866MHz) Tri-Channel With Airflow Fan (TR3X6G1866C7GTF) £191.99inc VAT ***
The TR3X6G1866C7GTF is a 6144MByte kit of DDR3 SDRAM DIMMs based upon Corsair’s ultra performance Dominator GT family of memory which includes Intel’s Extreme Memory Profiles (XMP 1.2). This enables a robust, profile based high performance DDR3 over-clocking solution for Intel X58 platforms targeted for enthusiasts, gamers and overclockers who want to extract maximum performance
from their platforms. Built using Corsair’s Dual-path Heat Xchange (DHX) technology coupled with a Corsair Airflow Fan, this part delivers outstanding performance in the latest generation of X58 DDR3 based motherboards. This memory has been verified to operate at 1866MHz at low latencies of 7-8-7-20 at 1.65V VDIMM.
- Three matched 2GB modules for use in high performance Core i7 systems
- Outrageously fast 1866Hz performance
- Ultra-low 7-8-7-80 latency
- Dominator GT with rosso corso accents
- Includes Airflow fan for increased cooling performance
- Density: 6GB (3x2GB Module)
- Speed: 1866MHz
- Timing: 7-8-7-20
- Type: DDR3
- Format: DIMM
- Included Accessories: Corsair Airflow Fan
- Pin Out: 200 Pin
- Voltage: 1.65V
- 100% tested at 1866MHz in X58-based DDR3 motherboards
- Lifetime warranty
Buy Now @ £191.99 inc VAT
*** Corsair XMS3 12GB (6x2GB) DDR3 PC3-10666C9 1333MHz Triple Channel (HX3X12G1600C9) £159.99 inc VAT ***
The XMS Series HX3X12G1600C9 is a 12288 MByte kit of DDR3 SDRAM DIMMs built using Corsair’s high performance heat sink which includes Intel’s Extreme Memory Profiles (XMP 1.2). This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at latencies of 9-9-9-24 at 1.60 VDIMM.
- 1333MHz DDR3
- CL 9-9-9-24 (CAS-TRCD-TRP-TRAS)
- Corsair XMS Heatspreader
- Lifetime Warranty
- 1.50 Volts
- 240 Pin DIMM
Buy Now @ £159.99 inc VAT
*** Corsair XMS2 4GB (2x2GB) DDR2 PC2-6400C5 TwinX Dual Channel (TWIN2X4096-6400C5C) £38.98 inc VAT ***
The XMS brand family is Corsair's mainstream line of performance memory. These modules allow users to experience outstanding memory performance and stability.
- Two matched 2GB modules for use AMD and Intel DDR2 systems
- Mainstream 800MHz solutions
- Latency of 5-5-5-18 for maximum reliability and performance
- XMS Heat Spreader
- Density: 4GB (2x2GB Module)
- Speed: 800MHz
- Timing: 5-5-5-18
- Type: DDR2
- Format: DIMM
- Pin Out: 240 Pin
- Voltage: 1.8V
Buy Now @ £38.98 inc VAT
