New CPU Advice Required
9 Jul 2007
At the moment I have the following -:
Asus A8N-SLI Motherboard (Socket 939)
AMD 64 Bit 3500+ CPU (Single Core)
2 x 1GB PC3200U DDR-200 RAM
Looking to upgrade the processor. A couple of questions.
Is it worth spending approx £50 on a AMD Athlon 64 X2 Dual Core 4200+ or spending approx £110 on an AMD Opteron 64 185, Socket 939, Venus Core, 2.6GHz, 2x 1MB Cache?
Or am I better binning the MB/CPU/RAM and buying a new setup, and if so, what do you recommend?
Depends, what will you be using your system for, games, browsing net/downloading, graphics work, encoding etc etc.??
EDIT: How much have you got to spend on new components and do you overclock??
Sell (don't bin!) your current kit (2GB of DDR has held its value tbh) and get some new:-
Thermalright Ultra-120 Extreme Heatsink (Socket AM2/LGA775)
(£32.89)
Intel Core 2 Duo E2160 "LGA775 Conroe" 1.80GHz (800FSB) - Retail
(£58.74)
Leadtek GeForce 8800 GTS 640MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
(£217.36)
OcUK 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit
(£82.24)
Abit IP35 (Socket 775) PCI-Express DDR2 Motherboard
(£88.11)
Total : £489.86
I've included a stoking graphics card in there, and OC to 3GHz and you have a top system.
Just my opinion but throwing new money at 939 is a waste.For a very reasonable price you could get into the C2D action,more so if you sold your current MB/RAM/CPU.
mainly for downloading & games with the odd bit of encoding now & again.
Budget is prob about £300
(£32.89)
(£58.74)
(£217.36)
(£82.24)
(£88.11)
Total : £489.86
Cheers for the heads up, should have mentioned I've got an ATI 512Mb RX1950 card already, not that bothered about DX10 at the moment :)
how much do you reckon you would be talking if I punted my system including 2 x 250Gb Maxtor HDD, Nvdia GT6600 Video Card, 1 x 16x DVD Recorder, 1 x 48x CD Recorder/DVD Player + 20" Viewsonic LCD monitor?
I would keep the Hdds as the resale value is peanuts due to the new pricing. CPU £30,80-£100 for the RAM and maybe £30 for the mobo.That would pay for a nice starter system.
probably going to hold at the moment, so back to my orginal question -:
What's the performance difference between the 2 chips?
sell your bits, buy a e2140 cpu, 650i board, 2gb cheap ddr2 and you are done:)
not worth putting money into that, its like putting money into an old skoda, just not worth it.
I know what your saying, but it's a hassle to break up the kit.
Are there any benchmarks for the E2140 vs AMD Athlon 64 X2 Dual Core 4200+ vs AMD Opteron 64 185 Venus Core, 2.6GHz?
Im only guessing cos never had a dual core myself, but I reacon it will be quite abit faster. Im building a 4200+ x2 for my m8 in a few days times, and it will be intreasting to see how much faster it is then my fx55 cpu.
