New CPU build for Pepar3D
17 Apr 2012
Hello everyone.
My i5 3570k OCed at 4.4GHZ is starting to struggle these days with the latest Flightsim addons for P3D v3.4.
I am looking at CPU, Mobo and RAM bundles and my budget is around £500-£600.
Would anyone have any recommendations? Looking at perhaps the 8700K chipset but may be out of my budget?
I also already have: Corsair H100 cooling, Geforce 1070 FE graphics card.
Alex.
Thanks, I can up my budget I guess!
Is anyone here able to put together a bundle or do OCUk do them?
looking at V4 recommended seems your core should be fine - you have got the option of dropping in second hand i7 to save costs .
not sure how Ryzen holds out with this sim, as if you need cores- its got cores!
whats your GPU currently - seems the sims different graphic options either effect GPU or CPU heavily
Currently Geforce 1070
