New Cpu cooler 1150 socket
27 Mar 2006
Using a BeQuiet shadow rock SR1 cooler with push pull and corsair fans chilling my 4770k at 4.6ghz. Temps are pretty standard considering the 1.22volts I'm putting though it. Idle about 30 degrees but high 70s to low 80's when I cane the system with a heavy encode. I'm hankering for something superior. Im aware of the corsair H100i and the latest Cooler Master all in one water coolers. Can someone advise me if it's worth me changing for a better air cooler or plucking up for something like the H100i. Thanks
Tbh your temps are pretty much ok for a haswell at that speed. Due to how they're designed they're just a hot running chip and it doesn't make much difference what you cool them with.
