Hello
Recently I changed my CPU and now when I try to turn on my PC everything starts as always but now after about 5 sec running Red VGA Led comes on on the motherboard and after few more seconds the PC turns off and I dont get any Display at all Monitor does not even power up
I tried to switch back to the old CPU
Restarted the CMOS
Checked every cable every connection
Reseat the GPU
Reseat the RAMs
Update: Tried to use brothers GPU r9 380 ( Not sure ) but still the same problem
Update2: Tried brothers GPU again and the PC will Display but turn off after few sec again
Tried the RAMS in brothers PC they work
Tried the my GPU in brothers PC and it doesnt work but then why doesnt his GPU work in mine? ( Works but turn off after few sec anyway )
None of it helped
Any ideas what should I do next?
CPU - Fx8320 or Fx9590
Mobo- Asus crosshair V formula ( Not Z )
GPU - FXF amd r9 290x
Restarted the CMOS
Reseat the GPU
Reseat the RAMs
None of it helped
