New Cubitek Cube Case - Move over Prodigy????
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys.
We have a new contender in the running for the best Mini-ITX case. For the past 12-18 months it has been the Bitfenix prodigy, but could Cubitek new offering beat it into the ground.
Cubitek Mini Cube Mini-ITX Case - Black @ £82.99 inc VAT
Mini Cube is the world’s first Mini ITX chassis supporting cable management behind the MB tray. With the fully aluminum Mini Cube, Team Cubitek gives Mini ITX gamers maximum performance in a minimum space. The expertly designed internal structure holds the powerful hardware gamers need in a minimal chassis. With options for both air and water cooling, optimal operating temperatures are guaranteed. The world's first Mini ITX case specifically designed for cable management, the Mini Cube gives gamers a neat and organized interior.
- Size: Case Dimension (mm) W 200 H 320 D 300
- Net Weight (KG): 2.3
- Material: Aluminum
- M/B Type: Mini ITX
- Drive Bays: 5.25" Drive Bay N/A
- 3.5" Drive Bay: Hidden x 3 ( Max)
- 2.5" Drive Bay: Hidden x 5 ( Max. )
- I/O Panel: USB 3.0 x 2 / USB 2.0 x 2 / Audio x 2
- Expansion Slots: 2
- Cooling System: Rear 80 or 90mm Fan ( Optional )
- Bottom: 120mm Fan ( Optional )
- PSU: Standard ATX PSU ( Max. 150mm )
- Maximum Compatibility: VGA Max. 280mm long
- CPU Cooler: Max 150mm height
Only £82.99 inc VAT.
ORDER NOW
