New Cubitek Cube Case!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys.
We have a new contender in the running for the best Mini-ITX case.
Cubitek Mini Cube Mini-ITX Case - Black @ £82.99 inc VAT
Mini Cube is the world’s first Mini ITX chassis supporting cable management behind the MB tray. With the fully aluminum Mini Cube, Team Cubitek gives Mini ITX gamers maximum performance in a minimum space. The expertly designed internal structure holds the powerful hardware gamers need in a minimal chassis. With options for both air and water cooling, optimal operating temperatures are guaranteed. The world's first Mini ITX case specifically designed for cable management, the Mini Cube gives gamers a neat and organized interior.
- Size: Case Dimension (mm) W 200 H 320 D 300
- Net Weight (KG): 2.3
- Material: Aluminum
- M/B Type: Mini ITX
- Drive Bays: 5.25" Drive Bay N/A
- 3.5" Drive Bay: Hidden x 3 ( Max)
- 2.5" Drive Bay: Hidden x 5 ( Max. )
- I/O Panel: USB 3.0 x 2 / USB 2.0 x 2 / Audio x 2
- Expansion Slots: 2
- Cooling System: Rear 80 or 90mm Fan ( Optional )
- Bottom: 120mm Fan ( Optional )
- PSU: Standard ATX PSU ( Max. 150mm )
- Maximum Compatibility: VGA Max. 280mm long
- CPU Cooler: Max 150mm height
Only £82.99 inc VAT.
ORDER NOW
Would have got it but ive bought a BD burner so would need it tbh.
Sleek, but a bit too simple for my taste. I know this is a popular style though, just not for me.
Will be happy with my prodigy when it arrives.
This will only work with GPUS which have a intake fan and exhaust out the back.
If you have anything else then its going to get way too toasty in there.
Lovely looking thing, sleek and elegant..but not so practical ( no drive bay) but than fixed with a USB external burner
*edit*
Wait, no USBs at the front ?
Nah prodigy still nails it for me, I don't think that I will be using anything else for a mITX build mate... nice case though... just not enough space :)
Stelly
*edit*
4 on the top edge.
Stelly
Prodigy is nice but too big for mitx imo, the FT03 mini nails it. Slightly smaller than even this Cubitek and a good 35% smaller than the prodigy.
ah sweet
I m looking at making a itx build at some point ( when I got the money burning my in my back pocket)
Looks nice but lacking 5 1/4 bay, stealth ODD tray front, handle, port covers, cpu cooler height ~165 and an matx version.
