Hi Overclockers UK,
I am looking to build a custom water cooling loop for my existing PC, which includes the following components:
I'm currently renovating an external outhouse, and due to the heat generated by my PC, I'm interested in setting up a complete custom loop. However, I'd like to utilize external radiators mounted outside and cladded over for discretion.
A few questions:
I'm considering using insulated copper pipework for the outdoor sections, then switching to quick connects once inside the property.
Additionally, would it be possible to use antifreeze in the coolant? If so, do you have any recommendations for types or mixtures that others have used effectively?
To combat condensation during the winter months, I'm thinking of incorporating some form of pipe heating system to slightly raise the pipe temperature and reduce moisture buildup.
Any help, advice, or recommendations would be greatly appreciated!
- MSI X870E Carbon WiFi
- Gainward Phantom 5090
- Delidded 7950X3D
A few questions:
- What fans would be best suited for this setup?
- What radiators have people used successfully in similar external configurations?
- Will I need extra pumps to handle the longer runs?
