Hi everyone
I have probably rly stupid question, but still its a question.
Few days ago I received new D5 pump and when took her from box I seen small metal part inside plastic transparent "snail" (all luck it is RGB model)
After closer inspection and disassembling pump. I found small metal "thing" similar to ball.
Also inside "black plastic part" of pump (I have no idea how its correct name ) I see two metal heads from pins or ball. Size will be hm.. almost this same to that what I found.
Pump was in original packaging, bag and box. I try to find photos of D5 inside. No luck.
So at this moment pump is still on my desk. I dont want to put it into loop if is damaged.
I send photos of that inside of "black plastic part" with two visible metal parts.
Maybe you can solve that mystery
Warranty? All fine and dont worry anymore?
https://ibb.co/RPgDqLS
https://ibb.co/NTT4YnN
