- 30 Mar 2017
Hi guys,
I know this may previously have come up, but I had an issue with my pump on my Lian-Li EKWB Distro and bought a brand new EK-Loop D5 G3 PWM Motor from EK.
My previous issue was noise from the pump and a high pitched sound that I am obviously hoping to sort with a new pump.
Do the attached images seem normal? The bearing plastic doesn't seem in great condition.
I wanted to do a quick test turning the bearing by hand. I initially felt resistance and when pushed a little more it turned and I heared a high pitched noise from the pump and some small black residue is present when taking off the impeller and inspecting the ceramic bearing.
I have not and will not run this pump in a non-primed dry run situation.
Just looking for peoples advice on testing this brand new pump. Should I not have turned it by hand? Thanks!
