Hi Guys
Our best selling dust filters by DEMCiflex are now available for new popular cases.
DEMCiflex Dust Filter Kit for Corsair 650D - black / black @ £45.95 inc VAT
These filters are custom made to fit the vents on a Corsair 650D case. these type of filters ensure that dust doesn't enter the case and build up substantially over time to cause component damage, these dust filters are removable and easily cleaned, with the light meshing and fine holes these filters do not cause lack of airflow, and allows fans with unhindered airflow.
Specification:-
- Top: 228.01mm x 324.02mm
- Side: 295mm x 350.03mm
- Rear: 121.84mm x 145mm
- Front: 200mm
Only £45.95 inc VAT.
ORDER NOW
DEMCiflex Dust Filter Kit for Corsair 540 Air - black / black @ £64.99 inc VAT
These filters are custom made to fit the vents on a Corsair 540 Air case. these type of filters ensure that dust doesn't enter the case and build up substantially over time to cause component damage, these dust filters are removable and easily cleaned, with the light meshing and fine holes these filters do not cause lack of airflow, and allows fans with unhindered airflow.
Specification:-
- Top: 148mm x 280mm
- Bottom: 148mm x 313mm
- Rear Side: 146mm x 124mm
- Rear Left: 232mm x 101mm
- Side: 143mm x 174mm
- Front: 140mm x 359mm
Only £64.99 inc VAT.
ORDER NOW
DEMCiflex Dust Filter Kit for Corsair 350D - black/black @ £34.99 inc VAT
These filters are custom made to fit the vents on a Corsair Carbide 350R case. these type of filters ensure that dust doesn't enter the case and build up substantially over time to cause component damage, these dust filters are removable and easily cleaned, with the light meshing and fine holes these filters do not cause lack of airflow, and allows fans with unhindered airflow.
Specification:-
Front: 273mm x 145mm
Top: 292mm x 151mm
Bottom: 203.07mm x 114.18mm
Rear Side: 47mm x 80mm
PSU: 87mm x 87mm
Rear Left: 117mm x 117mm
Only £34.99 inc VAT.
ORDER NOW
DEMCiflex Dust Filter Kit for NZXT Switch 810 - black / black @ £34.99 inc VAT
These filters are custom made to fit the vents on a NZXT Switch 810 case. these type of filters ensure that dust doesn't enter the case and build up substantially over time to cause component damage, these dust filters are removable and easily cleaned, with the light meshing and fine holes these filters do not cause lack of airflow, and allows fans with unhindered airflow.
Specification:-
- Side: 227.18mm x 166mm
- Rear: 129mm x 129mm
- Front: 134mm x 246.81mm
- Top: 369.25mm x 120.89mm
- Bottom: 129mm x 129mm
- PSU: 159mm x 136mm
ORDER NOW
DEMCiflex Dust Filter Kit for Corsair 900D - black/black @ £54.95 inc VAT
These filters are custom made to fit the vents on a Corsair Carbide 900D case. these type of filters ensure that dust doesn't enter the case and build up substantially over time to cause component damage, these dust filters are removable and easily cleaned, with the light meshing and fine holes these filters do not cause lack of airflow, and allows fans with unhindered airflow.
Specification:-
- Top: 550mm x 220mm
- Side x2: 520mm x 124mm
- Front: 375mm x 148mm
Only £54.95 inc VAT.
ORDER NOW
DEMCiflex Dust Filter Kit for Corsair 200R - black / black @ £40.99 inc VAT
These filters are custom made to fit the vents on a Corsair Carbide 200R case. these type of filters ensure that dust doesn't enter the case and build up substantially over time to cause component damage, these dust filters are removable and easily cleaned, with the light meshing and fine holes these filters do not cause lack of airflow, and allows fans with unhindered airflow.
Specification:-
- Side: 308mm x 168mm
- Rear: 180mm x 69mm
- Top: 390mm x 202mm
- Bottom: 153.30mm x 128.40mm
Only £40.99 inc VAT.
ORDER NOW
DEMCiflex Dust Filter Kit for Corsair 800D - black / black @ £39.95 inc VAT
These filters are custom made to fit the vents on an Obsidian 800D case. It can be ordered as a kit or as individual filters, depending on your setup.
Specification:-
- Top - 115mm x 355mm
- Rear - 153mm x 153mm
- PSU - 206mm x 153mm
- Bottom - 153mm x 153mm
- Top Rear - 157mm x 52mm
Only £39.95 inc VAT.
ORDER NOW
Specification:-
- Front: 200mm
ORDER NOW
Specification:-
ORDER NOW
Specification:-
Top: 292mm x 151mm
PSU: 87mm x 87mm
ORDER NOW
Specification:-
ORDER NOW
Specification:-
ORDER NOW
Specification:-
ORDER NOW
Specification:-
ORDER NOW
