** NEW EK GEAR INCOMING **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We have some serious EK gear due in next week.
The superb XTX Radiator series offers multiple porting routes, bleed holes and serious cooling capacity. Our initial shipment will be limited to a few units so be quick.
I am sure you will all agree that the new range looks brilliant!
We will be carrying the larger 140mm 'XTC' range by the end of the week too :)
Also, for those looking for a stylish and affordable way of filling your system, the brand spanking new EK single bay reservoir is made of rugged acetal and has a wonderful plexi fascia.
EK-CoolStream RAD XTX (480) @ £105.98 inc VAT
EK ultimate performance radiators are designed for extreme enthusiasts. These radiators are optimized for maximum heat dissipation even at lowest fan speeds. Choosing EK-CoolStream RAD XTX will give your watercooling system an upper hand you need to cool your hot hardware.
EK assured quality level and an optimal price-performance ratio make these EK-CoolStream RAD XTX radiators unique. The new radiators feature, besides their great design and high build quality, superb cooling performance.
The copper fins are optimized for both high- as well as low-speed fans therefore the new XTX radiator is an excellent all-around performer. The parallel flow cooling chambers reduce flow resistance to a minimum. Radiator shrouds are tapped with M3 threads on both sides to enable push-pull fan installation.
Radiator features G1/4 threaded ports on both sides of the radiator which enables various installation possibilites as well as stacking option. Bleed/fill/drain port, soldered to the bottom chamber, allows user a better overall handling and makes item more convenient.
Technical details:
Material:
- Copper fins
- 90% copper tube (H90)
- Brass chambers
- Steel housing
Dimensions (LxWxH): 520x130x64mm
Weight: Approx. 1826g
FPI: 11
Fan installation: 16 x M3 threads on both sides each (for 4x120mm fan each)
Pressure tested: 1bar
Enclosed:
- 1x EK-CoolStream RAD XTX (480) radiator
- 16 x M3 x 30mm DIN965 screws
- 16 x M3 x 5mm DIN965 screws
- 3 x G1/4 plug with Allen key
Important:
- The included screws may be too long for some applications. Always be sure to screw them in only so far that the radiator is not damaged.
- Over-tightening of the screws may damage the radiator. Always take care that the screws do not damage the radiator. Damages of the product because of improper use are not covered by the warranty!
- The radiator has integrated G1/4" threads, allowing installation of virtually all common fittings.
Only £105.98 inc VAT.
ORDER NOW
EK-CoolStream RAD XTX (360) @ £79.99 inc VAT
Technical details:
Material:
- Copper fins
- Brass chambers
- Steel housing
Dimensions (LxWxH): 400x130x64mm
Weight: Approx. 1496g
FPI: 11
Fan installation: 12 x M3 threads on both sides each (for 3x120mm fan each)
Enclosed:
- 1x EK-CoolStream RAD XTX (360) radiator
- 12 x M3 x 30mm DIN965 screws
- 12 x M3 x 5mm DIN965 screws
Important:
Only £79.99 inc VAT.
ORDER NOW
EK-CoolStream RAD XTX (240) @ £64.99 inc VAT
Technical details:
Material:
- Copper fins
- Brass chambers
- Steel housing
Dimensions (LxWxH): 280x130x64mm
Weight: Approx. 1175g
FPI: 11
Fan installation: 8 x M3 threads on both sides each (for 2x120mm fan each)
Enclosed:
- 1x EK-CoolStream RAD XTX (240) radiator
- 8 x M3 x 30mm DIN965 screws
- 8 x M3 x 5mm DIN965 screws
Important:
Only £64.99 inc VAT.
ORDER NOW
EK-CoolStream RAD XTX (120) @ £44.99 inc VAT
Important:
Technical details:
Material:
- Copper fins
- Brass chambers
- Steel housing
Dimensions (LxWxH): 160x130x64mm
Weight: Approx. 780g
FPI: 11
Fan installation: 4 x M3 threads on both sides each (for 1x120mm fan each)
Enclosed:
- 1x EK-CoolStream RAD XTX (120) radiator
- 4 x M3 x 30mm DIN965 screws
- 4 x M3 x 5mm DIN965 screws
Only £44.99 inc VAT.
ORDER NOW
140s are coming soon. need to speak to Eddy about pricing etc :)
i expect to see some build logs using these radiators, and some kind of bleed port/fill port on the system
whats the difference between teh EX range and RX range?
RX is thicker and top of the range? And ex the one i have is the slim line version,, the latest ones. what are these all about?
might have been tempted with one of the XTX radiators if I hadn't just got my SR1 (although it's not actually come out of the box yet, as I'm waiting for the rest of my gear to be instock...
Also, that Res looks nice, tempted to switch the dual bay one that I'm waiting for, for that.
Yea, just posted in the CS section to ask 5UB to sort it for me. I hadn't realised when I initially ordered it that you can hear the water falling into the res, not so keen on that, as I want it nice and quiet :)
Why no Cleee? It look nice - acetal;). I regret that I've ordered XSPC single bay. Unfortunately can't return, as I've opened it.
When they will be in stock? Gonna sell xspc one.
Nice try... but I have the same thing and love it. The Dual bay, IMO, look soooo much better than the single bay
The XSPC one looks a bit crap if you ask me
