** NEW EK WATERCOOLING GEAR COMING SOON **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Available to pre order from today onwards, we have the exciting new reservoir and LTX block range from EK Waterblocks.
These high performance pump top reservoir combos improve hydraulic performance of your DDC pump by such a significant amount, this type of solution is regarded as the number one choice for performance for the watercooling enthusiast.
We also have the new CSQ Reservoir range which includes multiple size options that accommodate multiple case types. It doesn't matter if you are watercooling in a Prodigy or a TJ11, There is a res size that will fit the bill.
All new CSQ reservoirs come complete with anti vortex technology
EK-DDC X-RES 100 CSQ - Acetal @ £35.99 inc VAT
High performance aftermarket pump top (volute) for Laing DDC series water pumps with integrated reservoir. This top offer increased hydraulic performance (up to 15%) compared to factory top.
This top features three G1/4 threaded ports of which one is inlet and two are outlets. By using the enclosed EK-Extender G1/4 installation of virtually any G1/4 thread fitting/barb is possible. EK recommends EK-PSC series compression fittings.
EK-DDC X-RES series reservoirs comes preinstalled with anti-cyclone insert. Additionaly a PU anti-vortex foam is enclosed.
Tube is made of quality acrylic material, while the volute / reservoir bottom is made of quality POM Acetal material.
Technical data:
- Reservoir diameter 60mm
- Overal Dimensions: 100mm
Enclosed:
- 1x Extender G1/4
- 2 x G1/4 plugs
- screws
- allen key
- anti-vortex polyether black foam
Made in Slovenia - EU!
Please note:
- Pump is not included!
Only £35.99 inc VAT.
ORDER NOW
EK-DDC X-RES 140 CSQ - Acetal @ £36.98 inc VAT
Technical data:
Enclosed:
- 1x Extender G1/4
- 2 x G1/4 plugs
- screws
- allen key
Please note:
Only £36.98 inc VAT.
ORDER NOW
OcUK Tech Lab - 10w DDC Pump & EK-DDC X-RES 100 CSQ Value Combo @ £89.99 inc VAT
Assembled in house by Expert OcUK Technicians
The DDC provides supreme performance alongside a tiny footprint.
This high performance aftermarket pump top for Laing DDC series water pumps with integrated reservoir offers increased hydraulic performance (up to 15%) compared to factory top.
Every OcUK DDC & EK X-RES combo is assembled by an Expert OcUK technician and tested for quality assurance before it ships to the customer.
Laing 10W DDC-Pump 12V DDC-1T Specifications
As the computer industry continues to accelerates its pace towards implementing liquid cooling solutions, pumps have become a pivotal concern for the adoption of such systems in mission critical machines. Small size, low or no maintenance, similar to that afforded by fans, and extended reliability are prerequisites for the successful transition from air to liquid cooling systems. Despite a remarkably small footprint of 2.4" square, the MCP350 features an astounding 13ft of head to provide superior flow rates in today's most complex liquid cooled systems. High reliability, high pressure industrial pump, featuring a 50,000 hour MTBF (5 year lifetime). Such reliability is afforded by the unique design of this pump, which contains only one moving part: the magnetically driven rotor/impeller spins on a single ceramic bearing, thus extending the life of this pump beyond existing standards. The pump is completely plug-and-play, and connects directly to any computer power-supply through standard 4 pin power connectors. It's compact design, quiet and powerful motor make it ideally suited for heavy duty cooling in environments where space is at a premium.
- 50,000 hours MTBF (Mean Time Between Failure) equivalent to 5 years lifetime
- Superior 12 Volts DC convenience: plugs into the computer power supply
- Superior real world performance thanks to its high pressure characteristics (13ft of head). Particularly well adapted to the proliferation of daisy-chained liquid cooling devices in a single circuit: Multiple Processors, Chipset, Graphics, and Hard Drives.
- Compact Design.
- Quiet Operation thanks to brushless motor. 24 to 26 dBA
- 3/8" barb fittings.
- No maintenance when used with de-mineralized water, and anti-fungal additives
- RPM sensor plugs to 3 pin motherboard fan connectors and reports impeller rotational speed.
EK-DDC X-RES 100 CSQ - Acetal Specifications
Technical data:
Enclosed:
- 1x Extender G1/4
- 2 x G1/4 plugs
- screws
- allen key
Only £89.99 inc VAT.
ORDER NOW
OcUK Tech Lab - 18w DDC Pump & EK-DDC X-RES 140 CSQ Value Combo @ £105.98 inc VAT
Laing 18W DDC-Pump 12V DDC-1T Specifications
This pump is the first pump worldwide which is used in mass-produced water cooled workstations and is ideal for the watercooling of processors and electronic components. Due to its compact size and its power it can be used for many applications.
This DC pump is an electronically commuted ball motor pump with an estimated lifespan of more than 50.000hrs at 12V. The only moving part on the pump is the spherically shaped Rotor unit which is sitting on an ultra-hard, wear-resistant ceramics bearing ball.
A conventional shaft with bearings and seals is not used or needed. The spherical bearing of the rotor unit on the ceramics bearing ball has many advantages: The development of bearing clearance is technically impossible which results in the impossibility of noise level increase over the lifespan of the pump. The bearing is self-adjusting, making the pump consistently quiet in operation over the full lifespan. The pump is directly lubricated by the coolant (wet-running pump). Therefore no maintenance is required.
As the rotor is magnetically held in place even small dirt particles pose no problem for the mechanism, a blocking of the pump is not possible under normal operating conditions. Even after a long period of standstill reliable operation is ensured. The permanent magnetic rotor unit is frictionlessly driven by a magnetic field which is produced by the surrounding stator.
The stator is completely built around the rotor, therefore the pump is with its 38mm only slightly higher than the stator unit. It therefore fits a in almost any PC case, may it be Super tower or Barebone. A separate magnetic shielding is usually not required. The ball motor principle allows powerful yet power-saving operation. The pump can be regulated by power variations of the DC operating voltage over a wide range. All parts in touch with the coolant are completely corrosion free.
- Motor design: Electronically commutated, brushless DC, spherical motor Voltage
- Range: 8 to 13.2 VDC
- 9 VDC required to start
- Motor rated at: 18W
- Max. delivery rate: 600L/h
- Maximum system pressure: 21.75psi, 150 kPa (1.5 bar)
- Temperature range: Up to 140F (60C)
- Corrosion resistant
- 50,000 hours mean time before failure (MTBF)
- Compatible with 3/8" ID Hose
EK-DDC X-RES 140 CSQ - Acetal Specifications
Technical data:
Enclosed:
- 1x Extender G1/4
- 2 x G1/4 plugs
- screws
- allen key
Only £105.98 inc VAT.
ORDER NOW
