Hi Guys
following the storming success of the LT and HF kits, EK have released a new range of kits which offer better value to the end user.
The new range of kits is supplied with the fantastic Gelid GC-Xtreme TIM
The LT kits remain much the same with small changes put in place to increase performance. The real changes are the HFX kits which come with EKs XTX Radiators. These ultra high performance radiators are amongst the best and provide the end user with a very capable cooling solution
The OcUK Tech Lab cases which feature EK Watercooling solutions have all been upgraded also with the new EK Kits.
EK-H3O KIT 120 LTX Performance Watercooling Kit @ £128.99 inc VAT
The EK-KIT 120 LTX is a basic water cooling kit dedicated to all users that seek quality and efficient, yet simple to use all-in-one water cooling solution.
Supreme LTX water block uses of the most efficient cooling engines. It offers exceptional value for money without sacrificing thermal- nor hydraulic performance. It's universal mounting mechanism allows installation on any desktop platform, including the newest Intel LGA-2011.
Single EK-CoolStream RAD XT 120 radiator will fit in virtually any modern computer chassis and will succesfully take heat out of your system. EK-DCP 2.2 water pump has been also proven by the enthusiast of the water cooling community as the one of most reliable water pumps.
Kit is easy to install, use and maintain, a thorough installation manual is included. Further descriptions and specifications of individual items can be found in EK webshop.
EK-KIT H3O 120 LTX water cooling kit includes following items:
- EK-Supreme LT - UNI (universal CPU block based on EK-Supreme LTX)
- EK-Backplate CPU Universal
- EK-CoolStream RAD XT 120
- EK-FAN Silent 120-1600 RPM
- EK-DCP 2.2 Pump
- EK-Reservoir Combo DCP 2.2
- EK-DCP PUMP mounting plate KIT
- TUBE Masterkleer 12,7/9,5 CLEAR (2 meters)
- EK-PSC Fitting 10mm - G1/4 Nickel (6 pcs)
- EK-Ekoolant UV Blue (concentrate 100ml)
- TIM Gelid GC-Xtreme (EKWB 2g)
This water cooling kit is compatible with the following CPU sockets:
- Intel LGA-775
- Intel LGA-1155/1156
- Intel LGA-1366
- Intel LGA-2011
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3, AM3+
IMPORTANT:
Distilled water needed to make the cooling liquid for the water cooling kit is not included. One needs to purchase 1L of distilled water which can be bought in any supermarket or petrol station. Please blend the distilled water and concentrate as per installation manual.
EKWB recommends using EK-KIT H3O 120 LTX for CPU cooling only. When adding more water blocks to the loop (i.e. VGA- or Motherboard water blocks) please purchase additional radiator (at least EK-CoolStream RAD XT 240) and fans. Single 120mm radiator is not enough for increased heatload.
EKWB recommends use of fan regulation adapters in case your motherboard does not support fan speed regulation. Such devices are not included in kit.
IMPORTANT NOTIFICATION:
- List of components may be subject to change in future according to EKWB's best practices.
- Distilled water needed to make the cooling liquid for the water cooling kit is not included.
- EKWB recommends using EK-KIT H3O 120 LTX for CPU cooling only. When adding more water blocks to the loop (i.e. VGA- or Motherboard water blocks) please purchase additional radiator (at least EK-CoolStream RAD XT 240) and fans. Single 120mm radiator is not enough for increased heatload.
Only £128.99 inc VAT.
ORDER NOW
EK-KIT H3O 240 LTX Performance Watercooling Kit @ £144.98 inc VAT
The EK-KIT 240 LTX is a water cooling kit dedicated to all users that seek quality and efficient, yet simple to use all-in-one water cooling solution.
EK-CoolStream RAD XT 240 radiator will fit in virtually in most of modern computer chassis and will succesfully take heat out of your system. EK-DCP 2.2 water pump has been also proven by the enthusiast of the water cooling community as the one of most reliable water pumps.
This kit can also be upgraded with an additional EK-VGA Supreme HF, EK-FB, EK-FC or EK-RAM series waterblock!
EK-KIT H3O 240 LTX water cooling kit includes following items:
- EK-CoolStream RAD XT 240
- EK-FAN Silent 120-1600 RPM (2 pcs)
- EK-DCP 2.2 Pump
- Intel LGA-775
- Intel LGA-1366
- Intel LGA-2011
IMPORTANT:
Only £144.98 inc VAT.
ORDER NOW
EK-KIT H3O 360 LTX Performance Watercooling Kit @ £156.98 inc VAT
The EK-KIT 360 LTX is a water cooling kit dedicated to all users that seek quality and efficient, yet simple to use all-in-one water cooling solution.
EK-CoolStream RAD XT 360 radiator will fit in most specially designed water cooling computer chassis and will succesfully take heat out of your system. EK-DCP 2.2 water pump has been also proven by the enthusiast of the water cooling community as the one of most reliable water pumps.
EK-KIT H3O 360 LTX water cooling kit includes following items:
- EK-CoolStream RAD XT 360
- EK-FAN Silent 120-1600 RPM (3 pcs)
- EK-DCP 2.2 Pump
- Intel LGA-775
- Intel LGA-1366
- Intel LGA-2011
IMPORTANT:
Only £156.98 inc VAT.
ORDER NOW
EK-KIT H3O 240 HFX High Performance Watercooling Kit @ £189.98 inc VAT
The EK-KIT 240 HFX is an advanced water cooling kit dedicated to all users that seek quality and efficient, yet simple to use all-in-one water cooling solution.
Supreme HF series water block is the top performing product. It offers nothing but the best thermal- and hydraulic performance. It's universal mounting mechanism allows installation on any desktop platform, including the newest Intel LGA-2011. EasyMount HF mounting systems ensured the perfect mount every time!
EK-CoolStream RAD XTX 240 is the highest performance radiator. Due to it's thickness of 64mm please make sure you computer chassis can accomodate it (EK also offers radiator holders for external mounting). EK-DCP 4.0 is a high performance water pump that has been proven by the enthusiast of the water cooling community as the one of most reliable water pumps.
EK-KIT H3O 240 HFX water cooling kit includes following items:
- EK-Supreme HF
- EK-CoolStream RAD XTX 240
- EK-DCP 4.0 Pump
- EK-Multioption RES X2 - 150 Basic
- EK-PSC Fitting 10mm - G1/4 Nickel (8 pcs)
- Intel LGA-775
- Intel LGA-1366
- Intel LGA-2011
IMPORTANT:
- Please make sure your chassis can accomodate thick radiator
Only £189.98 inc VAT.
ORDER NOW
EK-KIT H3O 360 HFX High Performance Watercooling Kit @ £214.99 inc VAT
The EK-KIT 360 HFX is an advanced water cooling kit dedicated to all users that seek quality and efficient, yet simple to use all-in-one water cooling solution.
EK-CoolStream RAD XTX 360 is the highest performance radiator. Due to it's thickness of 64mm please make sure you computer chassis can accomodate it (EK also offers radiator holders for external mounting). EK-DCP 4.0 is a high performance water pump that has been proven by the enthusiast of the water cooling community as the one of most reliable water pumps.
EK-KIT H3O 360 HFX water cooling kit includes following items:
- EK-Supreme HF
- EK-CoolStream RAD XTX 360
- EK-DCP 4.0 Pump
- Intel LGA-775
- Intel LGA-1366
- Intel LGA-2011
IMPORTANT:
Only £214.99 inc VAT.
ORDER NOW
- EK-DCP 2.2 Pump
- Intel LGA-775
- Intel LGA-1366
- Intel LGA-2011
IMPORTANT:
ORDER NOW
- EK-DCP 2.2 Pump
- Intel LGA-775
- Intel LGA-1366
- Intel LGA-2011
IMPORTANT:
ORDER NOW
- EK-DCP 2.2 Pump
- Intel LGA-775
- Intel LGA-1366
- Intel LGA-2011
IMPORTANT:
ORDER NOW
- EK-Supreme HF
- EK-DCP 4.0 Pump
- Intel LGA-775
- Intel LGA-1366
- Intel LGA-2011
IMPORTANT:
ORDER NOW
- EK-Supreme HF
- EK-DCP 4.0 Pump
- Intel LGA-775
- Intel LGA-1366
- Intel LGA-2011
IMPORTANT:
ORDER NOW
