New Element Cases from Thermaltake now in stock!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Thermaltake VL10001W2Z Element G Gaming Case - Black (No PSU)
This is the new Element G case, it is a great case with a black interior. The multi-coloured LED fans coupled with the red trim makes a bold statement showing you have a system designed for attitude.
- Colour: Black
- 3 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- SSD HDD Mounting built in
- Cooling: Front 200 x 200 x 20 mm Touchcolor,600~800 RPM fan
- Cooling: Rear 140 x 140 x 25 mm TurboFan, 1000 RPM fan
- Cooling: Top 200 x 200 x 20 mm Touchcolor,600~800 RPM fan
- Cooling Side 230x 230 x 20 mm Touchcolor,600~800 RPM fan
- Dimensions: 565 (H) x 231(W) x 526(L) mm
- Front I/O Ports: USB 2.0 x 2, Audio x 2
Only £99.99 inc VAT.
BUY NOW
Thermaltake VK90001N2Z Element T Gamer Case - Black (No PSU)
showproduct.php
Thermaltake have donned the gloves to challege the rest. Aimed at the mid-budget range this case is simple and crisp looking with an aura of quality and stlye. Built with a top mounted red LED fan for optimal cooling this case can be the perfect skin for your overclocked gaming rigs.
- Excellent thermal performance with optimal air flow
- Folding edge design to strengthen structure and prevent cutting
- Front (intake): 120 x 120 x 25mm (optional) or 140 x 140 x 25mm (optional) or 200 x 200 x 20 (optional)
- Rear (exhaust): 120 x 120 x 25 mm TurboFan, 1400 rpm, 17 dBA
- Top(exhaust): 200 x 200 x 20 mm red LED fan, 800 rpm, 14 dBA
- VGA (intake): 230 x 230 x20mm (optional) or 120 x 120 x25mm (optional)
- I/O Ports: 2 x USB2.0 and 1 x Audio
- Drive bays: 3 x 5.25", 6 x 3.5" and 1 x 2.5" SSD/HDD Bay
- Dimensions: 525 (H) x 210 (W)x 480(L) mm
Only £59.98 inc VAT.
BUY NOW
That was my opinion of the older TT cases, the Soprano range for example was dire.
The newer ranges are much better both in build quality and looks.
Both of these do look good though. Too much choice really for sub £60 cases... CM Elite 335, CM Dominator 690, Antec 300, NZXT Beta, Xigmatek MidGuard, Silverstone PS02B Precision, CM Centurion, NZXT Apollo, Hiper Anubis (though not for much longer :( ), Lancool Dragon-Lord PC-K58, Coolermaster Gladiator RC-600, Thermaltake V9 (maybe)... need i go on? Shame really that i'm not in the market for a new case. Got a free Akasa Eclipse from WJA96... albeit with a few holes in but that's not a problem :p
