New Epson Printer Install (Need Help)
1 Jul 2008
Torbados
Ok guys, so I got myself a new Epson SX215 all in one printer today and I've tried all I can to get the thing working but to no avail.
Installed the snow leopard drivers from apple, the corresponding drivers from Epson and no matter what I try my Mac just wont see the printer at all in System Preferences/Print Settings.
Any help would be amazing, if only to stop me putting a hammer through it! :D
You should probably know also that in my erratic frustrations to get the damn thing working I have installed both the above drivers plus gutenberg drivers and the ones that were on the disc, :( and have not a scooby how to find, delete and start again, should that be required.
Help me obi-wan you're my only hope!
This is very strange. I plugged this same printer into my Mac the other day, I got a Software Update pop-up, downloaded the drivers and it was working straight away. The supplied CD never left the leaflet.
Say What!!!
Tried the old just plug it in, its a Mac, it'll just work tactic but nothing.
To say I'm frustrated would be a gross understatement. In the 16 months I've been using Macs this is the first time things haven't 'just worked', so of course my world is near to ending. :D
It's very odd that it would be so inconsistent. I was shocked at how easy it was actually.
I know my posting isn't helping. :p Did you try the obvious things like running software update or changing the USB port?
Problem solved.
This is kinda embarrassing.
Turns out my printer cable which I've had a loooooong time is usb 1.0 and therefore not fast enough to communicate the info effectively to my Mac.
Cue usb 2.0 et voila, instant success.
Taxi!!!! :p
