*** *** Epson Stylus BX600FW Wireless Multi-Function Fax/copier/printer/scanner @ £99.98 inc VAT *** ***
Fast and feature-rich All-in-One inkjet for the busy office
Save space and optimise productivity with scan, fax, copy and print functionality in one device. Advanced paper-handling and excellent power-efficiency make this printer indespensible for any hard-working office.
Fast prints with no fuss
Print up to 38 ppm in draft mode, with 27 ppm mono and 19 ppm colour in business quality mode. Save time with the 30-page automated document feeder and 120-sheet capacity.
Flexible connectivity
The built-in USB, WiFi and Ethernet connectivity plus standalone function make it easy to integrate this printer into your network and centralise your printing.
High capacity, high quality ink cartridges
High yield, individually-replaceable ink cartridges ensure maximum cost efffectiveness. The extra large, high capacity black ink cartridge prints up to four times more pages. Quality is assured with DURABrite™ Ultra ink – producing professional colour or mono documents every time.
Low power comsumption
This device is more power-efficient than a laser printer. Our unique Micro Piezo™ technology allows printing with very low energy consumption and helps reduce your impact on the environment.
LCD Viewer
Explore this printer’s functionality through the impressive 2.5” colour LCD viewer for improved ease of use and PC-free operations.
Recommended inks
Epson DURABrite™ Ultra Ink, high yield individual ink cartridges. Less frequent cartridge changes and more time to get the job done.
- Device Type Fax / copier / printer / scanner
- Copier Type Digital
- Fax Type Super G3 - plain paper
- Dimensions (WxDxH) 46 cm x 41.1 cm x 23.5 cm
- Weight 7.2 kg
- Printing Technology Ink-jet ( colour )
- Inkjet Technology Epson Micro Piezo - 4-ink
- Max Copying Speed Up to 38 ppm (mono) / up to 38 ppm (colour)
- Max Printing Speed Up to 38 ppm (mono) / up to 38 ppm (colour)
- Max Printing Resolution Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Max Fax Transmission Speed 33.6 Kbps
- Fax Resolutions 200 x 200 dpi, 200 x 100 dpi
- Scanning 2400 x 2400 dpi
- Display 2.5"
- Original Size A4 (210 x 297 mm) (max)
- Document Feeder Capacity 30 sheets
- Media Size Legal (216 x 356 mm) (max)
- Media Type Plain paper, photo paper
- Standard Media Capacity 120 sheets
- PC Connection Availability Yes
- PC Connection Hi-Speed USB, Ethernet 10 Base-T/100 Base-TX, IEEE 802.11b, IEEE 802.11g, USB host
- Power AC 230 V ( 50/60Hz )
- Vista Certification Certified for Windows Vista
- Manufacturer Warranty 1 year warranty
View extended Specifications
Only £99.98 inc VAT.
ORDER NOW
LCD Viewer
Recommended inks
- Weight 7.2 kg
- Display 2.5"
ORDER NOW
