- 4 Oct 2005
- Herefordshire
So as the title says I would like to buy a new fan controller.
I have looked at the below ones. the ones with the fan pack just to add bling to my case and possibly use with watercooling. push/pull config ie have the BitFenix Spectre PRO fans on the outside and the static pressure fans on the inside ect ect*don't know if it would work ect)
OcUK Tech Labs Airflow Control Cooling Kit - BitFenix Recon Black + 4x BitFenix Spectre Pro LED Red
http://www.overclockers.co.uk/showproduct.php?prodid=BU-050-TL&groupid=701&catid=2331&subcat=2665
or
Aqua Computer Aquaero 5 LT USB Fan-Controller
http://www.overclockers.co.uk/showproduct.php?prodid=WC-011-AQ&groupid=701&catid=2331&subcat=189
or
Lamptron CW611 Watercooling Controller - Black
http://www.overclockers.co.uk/showproduct.php?prodid=CM-047-LP&groupid=701&catid=2331&subcat=189
anyhow ideas/thoughts please.
I would just like to say I would much rather not connect all fans via a splitter to my motherboard.
I will be watercooling from next month, so ideally I would like to connect as many fans to a controller without overly stressing it causing it to wear out early.
I have just bought a corsair 900d case so you can imagine the amount of fans I need to connect. obviously I will have to connect some to my motherboard.
Thank you
or
or
Thank you
