New fans in the case
19 Jun 2019
Hello,
I'd like to know how you would place the fans in my case to get good airflow(right now I have 2 mounted fans - 1 rear, 1 middle front). Also, soon I will buy cpu cooling for ryzen 2600.
Is it good to mount 2 fans under GPU ? I have RTX 2060 and I would like to oc it.
case - https://imgur.com/a/iYA449G
Probably I will buy Arctic P12 PWM PST(static pressure) or Arctic F12(high airflow), they are decent for this price.
fill front with intake and block off any holes in front panel not covered by intake fans. This way the air the intake fans are pushing into case cannot leak back out the front. I have case fans speed controlled so they speed up as component tmeps rise. Remove all PCie back slot covers for more vent area around GPU and thus more airflow around GPU. With good high pressure rated intakes in front you won't need any other case fans.
