- 28 Nov 2011
I have a fractal 3000 case.
I'm using the default fan controller which comes with the case, which controls up to 3 fans.
The case comes with;
2 X140MM (Intake at front, outake at top)
1x120MM (Outake at the back)
Connected them, they all work fine.
I bought another 120mm for the front, connected, it works fine.
Decided to go ahead and buy another two 140mm, one for the side and another for the top.
I have also purchased fan splitters where needed. Here's where it gets tricky.
So for each of the oriignal fan controller 3 pin connectors, i attached a splitter. turning 3 into 6.
The front two fans work fine, no problem with the splitter.
The top 2 fans are attached to the same splitter, the oriignal fan that came with the case is working, but, the new one isn't.
The same happens for the last splitter. Oriignal works, new one on the side doesn't.
Im guessing, there isn't enough power to power them all at once?
Is there any quick solution for this?
The fan controller is connected to the PSU via Molex Connection.
