Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail
MB-064-GI Gigabyte GA_945PL_S3 (Socket 775) PCI-Express DDR2 Motherboard
GeIL 1GB (2x512MB) PC5300 667MHz Value DDR2 Dual Channel Kit
Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM
NEC ND3550 16x16 DVD±RW Dual Layer ReWriter (Silver) - OEM
Asus TA-212 Series Midi Tower (Silver) - 360W PSU
BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail
My cpu fan stops spinning within a few minutes of windows loading. It works most of the time in the bios except when you restart it sometimes isn't moving. Also my cpu clock speed is 1.4GHz in the bios and the system window but 1.2Ghz in Everest when it should be 1.86GHz.
I looked at Speedfan as I thought it might be the PSU and it gave the following results:
Vcore1 1.18 - 1.23
Vcore2 1.84
+3.3 1.31
+5 4.92
+12 0 or 0.51 depending on what mood it is in.
-12 -16.97
-5 5.13
+5 5.13
Vbat 4.08
Speedfan also reads one of the temperature readings as -55°C and the cpu fan as 100000 RPM occasionally.
So do you think it is the PSU or could it be something else?
Thank you for your time.
Vcore1 1.18 - 1.23
Vcore2 1.84
+3.3 1.31
+5 4.92
-12 -16.97
-5 5.13
+5 5.13
Vbat 4.08
