New Flat Screen 15-19" Monitor
18 Feb 2006
Hey, im thinking about getting a new monitor in the near future. This will probably have to work with a X1800XL. Also atm i have a 15" TFT, which is nice as it is close to me but i have been told to get between 17-19"...Any Ideas?
Regards
Adam
well.. im not buying it yet, but need a cheap..decent 15-19" for gaming etc
edit: no short list
What is cheap to you? £100 or closer to £300?
As your graphics card can handle it I'd suggest a good 19" monitor, although if you're aiming towards that price bracket a 20" widescreen could be for you such as the Belinea 102535, consider that as well. :)
Failing that 17" monitors can be had very cheap and are a lot better than 15" monitors imo :)
yeah they are pretty good too. Plenty of info about all these if you do a quick search. Saves rehashing same info over again :)
not heard of that, no. with the availability of excellent models like the Neovo F419 and Samsung 913N, why bother though?! :)
Is the samsung 193T monitor considered old and slow by todays standards and would i really notice a difference by getting say the Viewsonic or newer samsung
thanks
