NEW FOXCONN BAREBONES NET TOP MINI PCs
11 Dec 2005
Cheshire
Due in stock this week, we have got two of the latest Foxconn Net top Mini PCs. Perfect for a discreet office system or even as a home theatre PC. VESA mount compatible for an ultra stealthy set up. Utilising low power consumption for a energy efficient set up. Simply select the SO-DIMM RAM of your choice and a 2.5" HDD and you are ready to go!
Foxconn nT-i1500 Intel NM10 Chipset DDR3 Nettop Barebones - Black @ £159.98 inc VAT
Small and exquisite shape brings you the enjoyment of the beauty , whilst enabling you enjoy the life with speed and share worldwide splendidness, is the best choice of being placed at home or office.
- Series: Atom
- Dimension: 190(W) x 135(D) x 24(H)mm
- Processors Supported: Intel Cedar View 2.13GHz Dual core
- Chipset: Intel NM10
- Memory Supported: 1x SO-DIMM Socket Support DDR3 1066 up to 4GB
- VGA Graphics: Intel GMA
- Storage Interface: 1x 2.5" SATA II 3Gb/s
- LAN: IEEE 802.11b/g/n up to 300Mbps
- Front I/O: 1x SD/SDHC/MS/MS Pro/MMC 5 in 1 Card Reader
2x USB 3.0
1x Mic in (support S/PDIF-IN)
1x Headphone
- Back I/O: 1x RJ-45 (10Base-T/100Base-T/1000Base-T)
4x USB 2.0
1x Line-out jack.(support S/PDIF-OUT)
1x HDMI
1x VGA
1x DC in
Only £159.98 inc VAT.
ORDER NOW
Foxconn nT-A3700 AMD A45 Chipset DDR3 Nettop Barebones - Black @ £199.98 inc VAT
Technical details:
- Series: Brazos
- Processors Supported: AMD E450 Dual core 1.65GHz APU
- Chipset: AMD A45 FCH
- Memory Supported: 1x SO-DIMM Socket Support DDR3 1333 up to 4GB
- VGA Graphics: AMD Radeon HD 6320
2x USB 3.0
1x Headphone
4x USB 2.0
1x HDMI
1x DVI
1x DC in
Only £199.98 inc VAT.
ORDER NOW
Quick question Nath, do these come with all the parts like RAM, HDD etc included?
If not can they fit inside the case if bought seperatley?
These are barebones units, so you will need a 2.5" HDD or SSD and SO-DIMM DDR3 to go with them to complete the build. An Operating system as well :)
How about a bundle for the lazy amongst us small SSD and some compatible RAM could make for a really good media centre.
