New Fractal Case in stock!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Fractal Design Core 3000 Midi Tower Case - Black @ £69.98 inc VAT.
The Core 3000 has plenty of cooling options, up to 7 fans of various sizes can be installed. The front panel is easily removable and pre-fitted with fan filters to ensure a dust free interior. The sleek black interior is matched and contrasted with white expansion slots and HDD trays. Similar to the Define Series, all the HDD trays are fitted with anti-vibration silicon grommets. The upper HDD cage is removable and rotatable, which enables support for even the longest graphic cards.
- Simple yet elegant front panel with mesh and filter
- Optimized for performance with multiple cooling options
- A total of 7 fan slots (1x 120mm + 1x 140mm in front, 2x 120/140mm in top, 1x 120mm in bottom, 1x 120mm in rear,
- 1x 120/140mm in side panel)
- Three fans included (1x 140mm in front, 1x 120mm in rear and 1x 140mm in top)
- 6x white painted HDD trays, with silicone mounting
- Upper HDD cage is removable and rotatable
- Easily removable front panel with clip on fan slots
- 1 front mounted Fractal Design 140mm fan @ 1000rpm included
- 1 rear mounted Fractal Design 120mm fan @ 1200rpm included
- 1 top mounted Fractal Design 140mm fan @ 1000rpm included
-Additional 4 fan slots available for optional fans; one 120mm in front, one 120mm in bottom, one 120/140mm in top and one 120/140mm in side panel
- 4x USB 2.0 and Audio I/O – mounted on top of front panel
- Removable filter below PSU (PSU not included)
- M/B compatibility: Mini ITX, Micro ATX and ATX
- 7 expansion slots with sleek white painted brackets
- Supports graphic card lengths up to 270mm when removable HDD-Bay is in place
- Supports graphic card lengths up to 420mm without removable HDD-Bay
- Supports CPU coolers with height of 160mm
- Supports PSU's with a depth of maximum circa 160mm, when using bottom 120mm fan location. When not using the bottom 120mm fan location, the case supports also longer PSU's, typically 250mm
- Case size (WxHxD): 200x430x480mm with front and top bezel in place
ONLY £69.98 inc. VAT
BUY NOW
This has removable HDD bays, so the fixing/removable mounting takes up slightly more space. Also this case is 1cm lesser in height
Damn I saw the start of the title and was hoping you had got the Arc in stock :(
Oh well, that is still a nice case.
Brilliant. I wish I could afford it though :(. The price is too close to the Define R3 for my liking though. If I had that amount of money for a case I'd pay up the extra tenner for the R3
Looks nice as a mid-budget case, knock a tenner off and it'll do well, it's just too close in price to lots of other decent cases right now.
Here you go,
Fractal Design Arc Midi Tower Case - Black @ £74.99 inc VAT
This new Arc Series Midi Tower format offers plenty of cooling options, up to 8 fans of various sizes can be installed. Unique for its small size, it also offers room to mount a thick, dual 120mm radiator in the top panel.
Elegant top and front panels are both easily removable and pre-fitted with fan filters to ensure a dust free interior. The sleek black interior is matched and contrasted with white expansion slots and HDD trays. Similar to the Define Series, all the HDD trays are fitted with anti-vibration silicon grommets. The upper HDD cage is removable and rotatable, which enables support for even the longest graphic cards.
Tangled cables are a thing of the past as the Arc Series offers an innovative, convenient, and great looking way to hide them away. The motherboard mounting plate has rubber covered holes in which you can easily route the cables to a compartment behind the motherboard, which has more than ample storage space.
- 8x 3.5 inch HDD trays, compatible with SSD!
- 2x 5.25 inch bays, with 1x 5.25>3.5 inch converter included
- On top of front panel: 2x USB 2.0, 1x USB 3.0 and Audio I/O
- No PSU included (removable filter below PSU)
- 1 rear mounted Fractal Design 140mm fan @ 1000rpm included
- 7+1 expansion slots with sleek white painted brackets
- Supports graphic card lengths up to 290mm when removable HDD-Bay is in place
- Supports graphic card lengths up to 470mm without removable HDD-Bay
- Supports CPU coolers with height of 180mm
- Supports PSU's with a depth of maximum circa 170mm, when using bottom 120/140mm fan location
- When not using the bottom 120/140mm fan location, the case supports also longer PSU's, typically 270mm
- Case size (WxHxD): 230x460x515mm with front and top bezel in place
Only £74.99 inc VAT.
ORDER NOW
Great to see a decent midi case that can take full ATX boards that is well priced. Fantastically priced on today only! Wonder how good the cooling is on these.
