Im currently saving up for a gaming rig which will get me through 3 years of uni as ill have no money to spend in the meantime. I have joined these forums and been reading about but its soo complicated and with all the competition about its quite difficult when you lack knowledge in it all. I am trying to pick stuff up but it takes time.
1. With the new bulldozer looking to be a bit of a dissapointment i was thinking about the Intel Core i5-2500 3.30GHz (Sandybridge) as it looks like the best value for gaming and can be overclocked pretty decently.
2. If money is not a major issue (Still got a limit) is it worth putting a watercooling system in it? I really like the look of the watercooling systems and the noise reduction is very appealing but would it just be worth getting "silent" fans and some rubber bits to minimise the vibrations?
3. Is it a good idea to get an SSD to run the windows from to make it run quicker and a bit more freely?
Basically could you spec me a gaming rig for about £1200 but also answer those questions so i gain a bit of knowledge, Thanks
