- 2 Aug 2006
- Liverpool
hi, can you please advise if I should make any changes to the following spec, overclockers uk will be building the system, I'm fairly happy with most things and I can't change to a different 3080 as ocuk say they will only use the one specced, main concern is the case and aio, the main use is 4k 165hz gaming
Case Corsair 5000D Airflow
Motherboard MSI MEG X570 Unify
CPU AMD Ryzen 7 5800X
CPU Cooler Alphacool Eisbaer LT360
RAM Team Group Xtreem 8Pack Edition 32GB 3600MHz
GPU MSI GeForce RTX 3080 SUPRIM X
SSD WD Black SN850 1TB
PSU be quiet! Dark Power Pro P11 750W
all items must be in stock
