New Gaming/TV Monitor Help?
21 May 2012
Hi all, hope well. Wondering if can get some advice. So running off some old old old TV 32", but wanting to finally upgrade to a better 4k Gaming Monitor - It will be used between my PC / Xbox Series X / General PC work (It won't be used as a TV). I had originally looked at buying the LG 32GQ950 . But it don't seem to have speakers & ideally something with a remote (but not the end of the world) - Gaming is really for likes of Simulator racing games, GTA / COD etc -
Running a - NVIDIA GeForce RTX 3080 Ti⠀ - graphics card It can't be any bigger than 32" that's the ideal size i'd like tbh -
hope you can help/suggest some good monitors etc
Thanks
just come across these also
Samsung Odyssey Neo G7 would be worth looking at it's a curved VA panel as opposed to the 2 flat IPS monitors you've posted above which would make it a more immersive gaming experience especially if you like to game with the lights out.
thank you, i shall check it out
