- 11 Feb 2006
- London
Hi there,
Currently thinking of upgrading from an older 8600GTS to a GTX 260, but I'm lacking in power connectors. The GTX260 requires two 6-pin connectors, my PSU only supplies one at the moment. I've only got one 4-pin molex spare running from the PSU, would it be safe to assume I can split the one remaining 4-pin molex then use a 2x4-pin molex to 6-pin PCI-E connector to provide the second 6-pin?
The other alternative, if I shouldn't split the one remaining 4-pin molex is to remove another 4-pin from a DVD drive, and make the drive redundant to then convert with my currently free 4-pin to power the GPU.
Any suggestions? There should hopefully be included with the GPU a 2x4-pin molex to 6-pin adapter.
