680's if you've got the space as they generally clock better than the 690's.
Hi All,
Im toying with the idea of either buying a pair of high-end NVidia GTX 680's or a single GTX 690 any advice on this please?![]()
What are your system specs and what do you want to use the cards for.
Portal 2 @ 1680x1050.![]()
Perhaps you can help me with a GPU upgrade - I can only get 30 FPS playing minesweeper.![]()
690. because its sweet. uses less power and makes less heat than the 680s. and performs so close i doubt any gameplay would be affected in any noticible way
