I recently bought the Inno3d 1080 Ichill edition from Overclockers and while I love the performance, there is something a bit strange about the card.
When I first installed it, I found that one of the displayport cables wasn't reliably connecting but I was able to make it work after wiggling it a bit (the answer to many PC problems, wiggle it a bit).
However, when I tried to plug in my Oculus Rift, I found that it didn't work at all (orange light on, but didn't turn white when worn and no video), so I decided to have another look at the sockets on the card and found that they are too close to the edge of the slot as below:
As you can see, they are very close to the top edge of the slot and that prevents the cables from being fully inserted.
I previously had an MSI 1070 EK edition (which fried itself) and the sockets were correctly positioned central to the slot, so why this card is different I have no idea.
I have checked and the card is correctly seated with the tabs at the bottom of the backplate in their slots and the top well aligned by the thumbscrews:
I am at a bit of a loss TBH and not sure what to do, I don't mind hacking a cheap displayport cable to make it fit and that is what I did, but I REALLY don't want to hack an Oculus Rift cable just to make it fit.
The only thing I can think of is take the card out and take a cutting disk to the case to make the slot wider.
Any thoughts and help gratefully received.
Dave
Dave
