New Half build advice please
6 Jan 2011
Hi All,
been doing a fair bit of research and just feel like I'm in the middle ground of choosing between AMD and Intel.
i want to spend £1000 , currently running a 6600k which is starting to feel slow and old and i wanted to start streaming as well as gaming.
the new parts i want are
CPU
MOBO
RAM
1 TB M.2
PSU (current is a 550 watt bronze rated and think its prob on the low side?)
2 TB slow hard drive
current GFX card is 980ti which im happy to sweat for a while longer.
whats your advice on what to get to help with gaming and streaming at the same time, could push budget a little if it was needed. Ill also just re-use my case, as i have a NZXT H440 noise dampened case.
thanks
Can't copy basket to here I'm on my phone
3700x
32gb 3600mhz ram corsair ryzen tuned
1tb nvme western digital
2tb hard drive.
Corsair rm 650 w psu
Gigsbyte arourus x570 motherboard
Arctic e34 cpu cooler
All comes to about £960
Mite be a bit overkill but hopefully others may help.
