Ive just added a new WD 1TB hard drive, i want to format it to jfs, but Gparted wont let me, so for the mean time ive had to format it to ext3. once this was done there was a folder in the drive called lost+found, which I had to delete manually using root commands, I then had to set the permissions in the same fashion. theres nothing on the drive, yet when you check the properties it says 46.8Gb used and 870.1Gb free. there are no hidden files but something is taking up 46.8Gb of space. any ideas?
