Not sure which model Seinheisers i have, not in that price range, they are lower, but they are better then any other headset i've ever put on head, minus the super expensive set my mate has (god knows what they are but he paid a lot for them).
I have the P160 model, they are well built and made to last. Once you adjust them I just bent mine to fit my head they are good enough for extended gaming sessions.
There is not much else to say about them I would recommend them but they are expensive. If you want a set to last a long time then they are the right ones.
I have recently started getting static in mine but I think that is due to the onboard sound which needs cleaning specially in this hot weather.
I had that, ended up being the old jack to rca cable i have in on my setup, replaced in with a new gold plated cable and its been crystal clear since. Have a fiddle with the cables and see if it helps.
