New HTPC Chassis
26 Aug 2012
Hello,
hopefully I'm in the right section!
If you can help me then it will be appreciated. I want to create a new home cinema media PC. I'm after a small chassis currently looking at the Silverstone LaScala LC19R Slimline HTPC Case - Black
http://www.overclockers.co.uk/showproduct.php?prodid=CA-141-SV&groupid=2362&catid=2282&subcat=
I can use the existing hardware i already have but would like to know what i may need to either fit into the new case or what i can salvage from the shuttle system i already have.
So, what I already have that i can use...
Shuttle SD37P20
Intel Core 2 Duo E6700, Conroe @2.66Gz
Shuttle, Glenwood-DG Motherboard
2 x 1Gb DDR2 - PC2-4300
ASUS 5450 Silent 512MB
Possibly looking to spend upto £200 (If needed but obviously would rather not :)) after the the purchase of the case above.
Main use is to playback my movies using XBMC which I've ripped with MakeMKV including Blurays..
Thanks!
