- 26 Sep 2008
Hi I've been building systems on a tight budget for about 5-6 years now, buying the odd upgrade here and there. I've got a few extra quid over the past few weeks and am starting a new build/upgrade.
So from my old system I've got a cheap Asus mobo running AMD 9550 BE (I thats the one), 4 gig of Corsair and a Sapphire 6870. This is in a CM Scout case and have two 160G HDs. This has stood me in good stead for the latest FPS games until now.
However, with BF3, Skyrim and a few others making autumn look very nice indeed, I thought a bit of an overhaul is required.
So over the last three weeks I've picked myself up
8G Kingston HyperX http://www.overclockers.co.uk/showproduct.php?prodid=MY-094-KS
Asus p67 Sabertooth 1155 http://www.overclockers.co.uk/showproduct.php?prodid=MB-449-AS
and
OCZ Agility 3 60G SSD http://www.overclockers.co.uk/showproduct.php?prodid=HD-075-OC
So first question is which CPU do you think, I'm probably looking at the i5 price wise as what says the i7 wont improve things too much. Is there much point spending the £30-£40 for the higher speed and unlocked ones. I've never overclocked much, maybe used the mobos standard oveclocks but if needed could I get the 2.9 up to the 3.3 speed?
Second - Do you think my GFX card will suffice, if not would you get another 6870 and crossfire or go for a 680. The 6870 looks the cheaper option but ive read bad things about crossfire support for AMD cards on new games.
Third and last (thanks for bearing with me) a cooler for the CPU. I was looking for something in the £40 price range, whats my best option at the moment. A few people have recommended the Antec Khuler water cooled option. Never been down this route but have heard it is easy enough to set up with better cooling than Air alone. Would you guys recommend this and would it fit in my Scout case.
Oh and 4th (I know I lied) anything else I should upgrade while I'm at it, maybe swap my storage to a single larger HD. Would this help with heat etc?
and
